Annoying problem
profile.country.no_NO.title
Litzala
Annoying problem
Hi.
When I turn my tablet, my screen does not rotate with it. Its stuck with the ridge on top. This is irritating, particulary when I'm reading e-books and would like to hold it with one hand. It startet doing this after the last update. I have to reboot the tablet and hold it the way I want it when its starting up, to get the screen to rotate.
Anyone else have this problem?
profile.country.nl_NL.title
breedBenR
perhaps installing the app 'Orientation Control' from the Play Store, fixes or provides a work around for your problem.
breedBenR
