clipboard on the tablet
tommysmith1980
hi everyone
ive just copyed some text of a web site and saved it, all good, it came up with a msg saying "copied to clipboard", can someone tell us where this is, ci cant find it anywhere, and if the are any better apps out there for note taking or copy and pasting text.
thanks.
4 REPLIES 4
lemurville
Tap and hold and a pop up box will appear allowing you to paste.
tommysmith1980
tried tapping and holding but still cant do it
Watashiwateshdes
Depending on the app, try just a quick tap. For some reason, this operates exactly like iOS, sometimes you need to tap and hold and other times a quick tap does the trick. Also depends on what you are trying to copy and paste. Text should be no problem but images for example are app specific.
Poria.m
Go to Google play store and install Clipboard small app.
Then tap the recent app button of your Xperia smartphone and find the clipboard small app by swiping small app list at the bottom of the screen and tap on it.
You see the clipboard!
(Removed email address)
