Howto: See if your Xperia Tablet S is not splash resistant
profile.country.nl_BE.title
degraaffn
This is an easy way to check for yourself whether or not your tablet has the flaw in splash resistency.
What you need to do, is hold your tablet flat in front of your eyes, so that you are looking at the bottom edge of the tablet.
Now look at the two bottom corners; if you see a small gap in either corner - it really is a very small gap - between the aluminum back cover and the black plastic edge around the display glass, then you will need to bring in your tablet to have the back panel replaced. Below are two pictures of the problematic gap:
0 REPLIES 0
