I have a question I need to know if I can use my tablet like phone
Danny_boom_
Rickard
Master
Hi and welcome to the community!
If you have the LTE-version of Xperia Z2 Tablet and insert a SIM-card that can be used for calls, you can make and receive calls with your tablet. You can either use it as a speakerphone or connect a headset.
4 REPLIES 4
Rickard
Master
Andman
If i have thi WiFi version of the Z2 it is not possible to insert a SIM right?
Because now I have a SIM for the tablet but i think putting it into the slot will be impossible
Rickard
Master
You can't insert a SIM card in the WiFi version of the tablet. The slot you see is for microSD cards. Please don't try to insert a SIM card there as it may damage the reader.
buschman31
I have just bought a used spg561 LTE verizon version. how can i tell if this tablet is unlocked?
