Marshmallow 6.0 "Battery usage" icons missing
SirRobin
As already posted in the Z5 forum, this problem also exists on the Marshmallow Tablet Z4 Firmware:
http://talk.sonymobile.com/t5/Xperia-Z5-Z5-Compact-Z5-Premium/Marshmallow-6-0-quot-Battery-usage-quo...
Gruß Sir Robin
--> KD-55XE9305 --
Rickard
Master
This is something that we have forwarded internally. I will let you know as soon as i have more information.
Rickard
Master
Rickard
Master
I've received some information on this and the reason they are grey after the update is that this is the standard color used for these icons in Android 6.0 so it's by design. But i've forwarded your feedback about making them more clear.
niclato47
Hi Richard,
You re right I checked on my nexus 7 2013 which is in android 6.0. But as you can see the grey icons are more comprehensible on nexus.
Left picture nexus
Right picture z4 tablet
Grey wifi icon on nexus vs grey circle on Z4 tablet
grey sun for display on nexus vs grey square on Z4 tablet
grey standby icon on nexus vs grey square again on Z4 tablet
