music
sadeamz
music
how do I transfer music from cds to my tablet?
sehuxle
First, you'll need to rip your CD's to your PC. Windows Media Player (WMP) will do the job. Make sure you use a high bit rate for better sounds quality. And make sure they're in MP3 format.
Then when all your CD's our on your PC use WMP to synchronise with your tablet. Plug the tablet into your PC using a USB cable and let WMP synchronise.
sehuxle
