tablet corrupts 64GB SD card?
sharonflowers
this has happened twice now...sd card fine, 64gb not recognised when put in, then when put into  pc, and then apple mac, no longer worked...said needed formatting...all videos and photos gone. I sent back the sd card and it has just happened again...only machine used both times was my sony tablet
help, it didnt happen to any other size sd card
rich912
Hi sharonflowers,
Which Tablet do you have and what format of SD card are you using.
The following link may throw some light on the problem.
http://www.sony.co.uk/support/en/product/SGPT111GB_S/news/sdxc_memorycard_tablet
Rich
Go n-éirí an bóthar leat
