Why is there no task manager in Xperia tablet Z?
JimNoap
i would really like some kind of feature to close all open apps/programs at once instead of shutting them down 1 by 1. Xperia Tablet Z owner.
Uliwooly
A taskiller its NOT a good idea, Android will close apps as it need RAM, also, when you exit an app press BACK instead of Home.
Again stay away from
taskillers
task managers
antivirus
ram apps
battery apps
booster apps
4 REPLIES 4
Uliwooly
taskillers
task managers
antivirus
ram apps
battery apps
booster apps
JimNoap
wow!
thanks for this info.  i always pressed home :<
i am so used to pressing short command on my galaxy to close all the junk i open at once. i guess its time to remove this bad habit.
also can u tell me why should i stay away from antivirus. i always thought avast is something i just must use.
Uliwooly
Antivirus will slow down your phone, drain your battery  and create other issues, as long as you download apps from the play store and don't visit dubious sites or open mysterious emails you should be ok, also keep the "install unknown source off " that way a website can not sideload their malware.
dnastase
I don't agree with not using task manager to kill apps.
As long as the apps get killed nicely (eg: not kill -9) then there is no downside.
It's the same story w/ manual memory management in C/C++ or the garbage collection in Java: there are pluses and minuses for both and it depends on the context of use.
