I have a Sony Vayo laptop with Radeon HD 3400 Series. Ever since i started connecting the SONY Bravia KDL-24EX320 to the laptop on the HDMI port ( as extended Desktop) my laptop crashes at least one or two times a day.
On the laptop there is a HDMI Resolution Setup interface and i selected the smallest option 720( there are also 768, 1080 possible) but still with this setting the crashes occur.
Have you encoutered such a problem?
I i find a solution in the mean time i will let you know.
Thank you,
Ruxandra
Message was edited by: ruxmanea
Solved! Go to Solution.
I found the solution for the behavior.
- I changed in Display Settings the option for Colors from Highest(32 bit) to Medium( 16 bit).
Now i don't have any crashes anymore.
Ruxandra
Hi ruxmanea,
welcome to Questions & Answers..:smileyhappy:
I'm glad to see your solved your crash problem & thanks for taking the time to post what the solution was, hopefully this may help others..:smileyhappy:
Thanks for your reply! It was only fair to post the fix, maybe someone has the same problem as i had( small chances but who knows...).
However is clear that this kind of LCD required a better Display adapter in order to use it at its potential.
Ruxandra
