- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
4k record lagging Xperia 1
I used the 4k recording on Xperia 1 ...it is kind of lag ..but in the cinema pro app it is working just fine...is it a software issues or it supposed to be like that?..is there any fix to it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
lag doesnt lag for most
the issue is stabiulity both in cinema pro and normal app.
Sony are on the case, though
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, 4k video is really choppy.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I filmed my latest video using the Sony Xperia 1 in 4k and the results were disappointing, I am wondering what problems everyone else is having? https://youtu.be/_QWpHU0i92c
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If I didn't know any better, I would guess you have either a lot of apps all running/syncing in the background, are using a crappy memory card(no matter what brand or if it's "good" , if you are recording onto SD.
If you are using an SD card, you really need a card that's capable of 4k recording say, in a dashcam, something with a high read/write speed.
I've tried Samsung and the high speed Sandisk, but found them poor and nowhere near what's advertised.
Best results so far are with MyMemory branded cards, advertised speeds, and no quibble lifetime warranty.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This has nothing to do with SD cards.
I've set my phone to record to internal memory and all my 4k videos are choppy, loosing frames and practically unusable. Also, no I don't have almost any apps running in the background as I use very few non stock apps and tested it as well just after factory reset without any additional apps.
This is Sony basically not caring about proper quality assurance of their products. Releasing a phone in 2019 with unusable 4k video recording? It's just pathetic and I'm not sorry for them loosing millions of $$$ on mobile division as they deserve it 100% for ignoring their consumers and releasing unfinished low quality products.
Also, no Sony is not on the case unless you can provide a proof of them:
1. Acknowledging the problem; and
2. Promising to fix it with future updates.
Can you? If not then we assume Sony doesn't care and will not fix it like with many other things they ignored over the years.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well, I can't say I have dropped frames or choppiness on my phone, and GilgameshUK has posted some videos before and after the update, and they look ok as well..
You might have a faulty phone, or your operator software might be borked, or there may be another issue.
I would report the fault, and also report the issue to Sony Mobile Support, rather than being "not sorry" and feeling they "deserve" to lose money, that's just an immensely childish attitude to have.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Do software repair on PC and if that doesn't help return it for new one. I don't have any problems with 4K recording on my XPERIA 1 like you have.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I tested a bit.
In the cinema Pro app I can confirm this chattering. (both 2k and 4k)
4k video isn't chattering in the camera app.
Dropped frames? Didn't notice.
