Android 12 Xperia 1 III full battery usage stats bug
Corruptedminds
Hey guys
Here is another bug on Android 12 not being able to display the full battery usage stats graph from 100% if you haven't charged the battery over a day.
Not critical but it can be confusing leading gyou to think the phone only had 50% charge as the graph only sees from 50% on the next day.
profile.country.PH.title
MarlonUk1
as far as i know if you fully charge the device the graph will reset. try to observe the graph after a full charge
Corruptedminds
The bug here is that the readings stats from 100% are not there as the graph does not fit this info / scale.
