Hi, can somebody explain me how i can set a different sound for messages than others notifications. It was possible with previous Xperia Z5 compact directly from message app but i'm not able to find that on my new Xperia 1... Thanks
Solved! Go to Solution.
Hi @chrispuj, let me see if I can help out here!
In order to change the tone for incoming messages, Open the messages app > Tap the menu icon in the top right corner (three vertical dots) > Tap Settings > Tap Notifications > Tap "Other notifications" > Tap Advanced > Tap Sound.
I hope that helped!
I hope that helped!
Thank you Martin, it was a bit hidden 🙈
