Heat Suppression in Video Calls on Xperia 1 II
Speedbird139
Heat suppression in Game Enhancer seems like a fantastic feature to reduce battery degradation. I was trying to add Google Duo/WhatsApp to it but it doesn't allow it. Is there a way to use heat suppression when on long video calls? My phone heats up because I have to charge while on call to keep the battery from discharging.
Sean_Mc
Moderator
Hi there,
I'd recommend contacting the Mobile support team here for further advice.
Best wishes,
Sean
Speedbird139
Hi, thanks for your message, I tried contacting them. Their reply was genuinely disappointing, a generic "try software repair, etc.", they probably don't even read the messages.
mamller6487
Yes, first you get an autoanswer :slight_smile: saves cost I think.
Replay to the message say you do all the s.... and nothing is changing. Perhaps a real person will read your message.
