how I restore the data?
heena_khan
hello I want to restore my data what should I do to restore the data I have importent data in my phone so waht should do to restore the data help me out fast.
Tags (3)
RottenFoxBreath
Enthusiast
You can either email it to yourself, or use an micro SD card, copy it to the card, and then its saved, or back it up to a cloud service.
If you have already deleted the data, or done a factory reset, well, it's gone for good, and you aren't getting it back.
nairsuresh0828
You can restore your data in a pendrive using otg cable or you can store it on the cloud. You can also transfer all your data from mobile to laptop or computer.
