Is it normal for cinema app to....
Beastkut
 Why my cinema app has a sprinkler thing on the screen?
10 REPLIES 10
Jon.Hidden-Coley
I'm assuming you have Cinema Pro open in total darkness (or face flat on a table)? I've just opened Cinema Pro in our darkroom using the same settings as you had and I get the same thing but only at a high ISO. So yes, I would say it's normal. It doesn't cause any issues under normal usage.
Urrl
It is not normal. I was about to post this topic also. It is definitely a software issue. You can prove this by stopping the app then going into settings and clear the cache and data for this app. Once you reboot the phone there should be no sparkles even at high ISO setting. You can record clear video even in near darkness. However over time the sparkles will return.
Jon.Hidden-Coley
Yep, you're right. It only seems to happen to me when the LOOK is set to N/A though which I never have it set to that.
Beastkut
No i open it in a quite bright area...i just put my hand close to the camera so you can see the thing clearly
Jon.Hidden-Coley
Looks like an issue Sony need to look into asap!
Lord_viridis
Hot pixels show in high iso darkness after a short amount of use, clearing the cache and rebooting is just letting them cool.
Do  the hot pixels show in normal use? That's the question,
Jon.Hidden-Coley
On my testing, the sparkles only appeared at ISO 500 upwards and 360 degree shutter (even during recording) and only using the 16mm lens. Screen also showed a strange moire pattern, The pic below shows the pattern, I've lowered the ISO to make it easier to see.
However, in order for me to get the sparkles to show, I had to start Cinema Pro with the lens covered so there was no light entering the camera, set to high ISO, 360 degree shutter then uncover the lens which in most cases gives a terribly over exposed image. Making those settings under normal use, ie in natural light, no sparkles appear.
For me though, it only happens when selecting n/a for the Look. Simply switching to a different Look and the sparkles / Moire pattern disappear, even if I go back to the n/a Look.
Buddy122
Yes looks they only appear in N/A mode.
Beastkut
You are right...but if you on and off the stabilizer ...the thing will disappear
