PLEASE HELP - NO OTA but on Xperiacheck there is update for my phone??
Robi_2109
PLEASEEE HELP After so long waiting for my Xperia 1 Telekom LC today on Xperiacheck comes update for my J9110, its says 55.1.A.3.49-R4B , probably its Android 10 but there is no OTA ?? On Support app its says there is update for you through Xperia companion, but i dont have any laptop on computer , i have only Tablet Windows 10 but i cant connect it with my phone because tablet dont have USB type c connector. How can i update my phone ?? Why there is no OTA if there is update for my phone??
19 REPLIES 19
Robi_2109
Update through xperia companion, but still no OTA 😕 i check for update 200times per day and still no luck. Whyy???
RamonRJC
Did u install the update now? I still can't...
My phone says it is availble by companion. Companion says my phone is up-to-date. When I manually check for software update my phone also says is up-to-date. So weird...
Robi_2109
Same here, shows update on support app but still no OTA? Sony is so bugged
blegs
Using software repair to update this firmwire
Robi_2109
Explain please? First i must start softwere repair and then start update from xperia companion or? Can you write steps how to update from xperia compaion?
RamonRJC
I did this and now my phone uses Android 10 and the security patch from 1st january.
But when u do this, make sure you make a back-up, cause u will lose everything.
Just using Software Repair installs Android 10.
Dark mode is very nice and the new gestures makes the phone a lot quicker!
Robi_2109
I cant connect my Xperia 1 with laptop because xperia uses usb type c from both sides and my lap doesant have usb type c port. I have another usb cable and when i connect it with phone and lap nothing happens, lap cannot recognize any phone 😕
RottenFoxBreath
Enthusiast
No it doesn't, you can use a usb to usb c cable for a pc..
Robi_2109
OTA finally come
profile.country.ES.title
Ciro1976
there is no other for EU rom
