Shot in Bradford, With original xperia 1
Gilgameshuk
Slight editing in Snapseed, for some reason if had a slight perspective issue (walls looked bent) and believe me the lens flair was much worse before, now I can live with it.119667705_2130429200435169_6289396175038726476_n.jpg119675506_321233225991456_8807829217791849883_n.jpg
Gilgamesh the first ONE and ONLY King
Sony_UK
Wow
And again wow.
If you don't mind could tell us your setup for this and how you achieved this.
Gilgameshuk
Taken on the OLD sony xperia 1 (2019 model)
used the manual controls and HDR on this and set it to 1 stop underexposed in order to try and reduce some of that lens flare (trust me it was much worse)
Then i used the physical camera shutter button and tucked held the phone a little like a dslr this then allowed me
to tuck my elbows into my stomach-thus forming a tripod of sorts.
Imported into Snapseed, simply brightened the picture a little bit  and fixed perspective as the walls looks really bent (possibly at the weird angle i shot it at)
that's it .
