I have updated my Xperia 1 phones software the other day and I have noticed tht another of my apps are either freezing or are really slow to load up. Pls can anyone advise wht I can do and if others are having the same problem
Try restarting your phone.
Clear the app that is acting up cashe.
Check to make sure the app is updated.
If issue contriunes reach out to that app developer.
Thanks for that but it's not just one app it several and it's since I had the software update
