Kc718
Verizon xperia 1
I've seen an article saying the xperia 1 is able to be used on Verizon,  is this true?
I would really want to buy this phone
12 REPLIES 12
SAWIG
I had no issues when I chatted them. I told them what I had and what I wanted to do and it took them couple of minutes. Then they called me to verify the connect and call quality. I am unfamiliar with the "Roam" option. I am also not sure why they just don't switch everyone to CDMA-less since they are eventually going to take down CDMA.
Mrhug3
Maybe the tech I had dealt with wasn't as adept at all the inner workings of getting unlocked phones to work. Either way, I had to get a new SIM. Glad everyone is getting up and running.
ChCA
I finally solved it thanks to you!!!!!
I finally went to the VZW store ( not an authorized )
and I was able to call Verizon Technical support.
I didn't know VZW store ( not an authorized ).
Thank you Mrhug3.
I don't understand the Verizon mobile phone system.
I called  Verizon Technical Support( 1-800-922-0204 )
and I asked "Activate a CDMA-less device".
I received the text message with it.
Thank you SAWIG.
Thank you BlebeR.
Thank you for all your kindness.
I solved my Xperia 1 probrem.
I sincerely appreciate your swift actions.
