Why Sony limits SD card speed to about 30 MB/s?
ds2mph
SanDisk Extreme Pro 400GB V30 A2 (read write speeds up to 170/90) gets only about 30MB/s on the Xperia 1. (Tested via A1 SD Bench)
Why SD Card speed is limited to 30MB/s?
It seems All Xperia flagships (excluding Xperia XZ Premium,XZ1,XZ1 Compact) have this limitation.
/t5/Xperia-XZ2/2018-Phone-SD-Card-limited-to-18MB-s/td-p/1319383#gref
8 REPLIES 8
Uliwooly
@ds2mph
which app are you using to test the speed?
ds2mph
A1 SD Bench
Avril
azzido
Enthusiast
Any answer from sony mobile engineer on this topic?
Sony4KFoneLvr
Sony, can you respond? For a 4K display phone, it should allow fast speed. Thanks
azzido
Enthusiast
Maybe they do not limit it but use cheap reader in X1 Slightly_frowning_Face
ds2mph
https://forum.xda-developers.com/xperia-xz2/how-to/micro-sd-read-write-speed-t3783000/page7
https://forum.xda-developers.com/showpost.php?p=78870686&postcount=436
So, it is a software limitation...
Can be fixed by software update..
But as always, Sony mobile will never fix this problem.
pressefr
Wouldn't the larger the SDcard, 400GB, the slower the write speed. It's the card vs the phone. No?
For example when I switched to 4K video option it asked if I want to use internal memory. Since a 64GB Ultra cards are made for recording 4K for it's faster write speeds.
I have my own small issues; I currently use a 400GB SDcard. Once and a while when I pull out my phone to take a picture I get an error like 1/4 times randomly my Xperia 1 can't read my SDcard. I partly think it's to large for a its own good.
https://www.androidpolice.com/2019/02/13/sandisk-a2-and-400gb-microsd-roundup-review-buy-for-storage...
