Has anyone else been experiencing WiFi disconnects since the last update?
WiFi had been perfect on my XP1 but over the past 2 or 3 weeks I will be surfing and randomly get a "no internet connection" error. I find the WiFi connection had dropped, and within 1 second or so it reconnects again and I can continue.
It's just like it was a few months ago with the 4G connection dropping problem. Just random loss of WiFi signal instead of 4G signal.
Has anyine else been experiencing this, or is it just me?
you are not the only one,
try to re connect with the wifi network from scratch ie. forget and delete network name on the device and reconnect.
also try to see if it disconnects on safe mode ,,, if not , try to perform software repair using Xperia Companion
