I've got Xperia 1 and it didn't connect to my 5 Ghz wifi!!!!
Could anyone please help me!
You will have to elaborate a bit more to be able to get useful answers.
Are you able to connect to any WIFI network at other locations?
Is your 5 Ghz WIFI visible in the list of available networks? -If not, maybe the networks runs with hidden SSID.
Do you get some sort of error-message, or what happens when you try to connect?
Hello runej and thanks for the quick response
The main problem is the mobile connect only to 2.4 Ghz wifi and the 5 Ghz wifi doesn't show when i scan for! It only appear when i put on airplane mode!
Can you connect OK to the 5Ghz WIFI when in airplane-mode? (aka do you get internet access on the 5 Ghz network)
And also, when in Airplane-mode, do you see both the 2.4 Ghz network and 5 Ghz network at the same time in the list of available wifi-networks?
I can connect to 5 Ghz in airplane mode and i get internet access... And YES the 2.4 Ghz and 5 Ghz both appears in the list n airplane mode
That was strange.
Try to turn off the Auto-network-switch under Advanced in WIFI Preferences.
If no progress, try to boot your phone into safe-mode and see if you get any different results? (aka an app or something is tampering with the network-access)
Brother i did these steps yesterday and it didn't work!
Actually I've got the same issue on my last XZ premium and i thought that the XZP doesn't connect to 5 Ghz in the 1st place 🤷🏻♂️
It would then seem like the issue is with that particular wifi-router you are trying to connect with.
Tried to connect to another 5 Ghz wifi somewhere else? (coffee-shop, work, school)
If that works, the issue is either firmware or settings in the wifi-router.
PS: My XZP did connect to 5Ghz network at home and at work with no issues.
I've got 5 Ghz in my home and my work and still the same prob... idk what's the matter but thanks alot for your patience and i hope it's a firmware upgrade issue!
Thanks again 🤗
@Ahmad_abed86 wrote:I can connect to 5 Ghz in airplane mode and i get internet access... And YES the 2.4 Ghz and 5 Ghz both appears in the list n airplane mode
Something is not right, in Airplane mode, the network and radio transceivers are turned off to prevent disturbance to sensitive equipment, so you shouldn't get any internet whatsoever.
