Hi
I have an Xperia 1ii and RODE Videomicro Mic with the correct connecting cable. The mic works when I use the Simple Voice Recorder app but not when I try to use it with recording video. Does anyone know why and how to fix it? I'd be really grateful
Thanks. Greg D
Can you check if you need to enable a specific permission for the Mic on the camera app if that's what you're using to record videos
have you checkled if the mic supports a TRS system
I know for mics etc it needs a TRS to TRRS cable
my mic came with a converter to do just that and its a cheapo one from ammazon
