YouTube flickering when screen rotates
Sambol23
I have an issue where everytime I rotate the screen the screen flickers (goes brighter, then dimmer). Anyone else experiencing this issue or know any solution?
RottenFoxBreath
Enthusiast
If you have adaptive brightness on, chances are it's you causing it, and covering the light sensor when rotating the phone.
Lord_viridis
Yup, if it's the one where as you rotate the screen goes bright, then normal once rotation finished, it's normal and is due to a limitation on androids rotate animation rendering on HDR videos.
Seen it on loads of devices so far
