Ambient sensor reaction time
Inchka
Hi, I'm new so please be gentle.
When I use the fingerprint sensor to open the handset in bright light like outdoors in daylight, the display starts very dark, and it takes around 4 to 5 seconds for device to adjust brightness for screen to be useable.
Is this normal??!
Inchka
Bump?
pressefr
You mean "adapitive brightness" feature.
Display > Adaptive brightness"
Note: supposedly moving the slider manually a few times outside the AI will kick in.
(I personally don't use that feature, I'll give it a try myself and see how the reaction time is.)
This prob has no effect, perhaps also turn on, so the screen stays on while staring at it.
Display > Advance > Smart backlight control
