Does it has any game recording gesture?
amber_ketch
Does Sony Xperia 10 Plus comes with any game recording gesture that we can make screen recording on video games and shares on YouTube or Facebook?
The other phones have and that is a very good feature for gaming communications.
Uliwooly
@amber_ketch
Its just an extra step using an app, it has been like that for years, that doesn't mean that it has to remain the same, send your feedback to Sony and if you know of any other users that would like the feature to do the same
https://support.sonymobile.com/global-en/contactUs/
4 REPLIES 4
Uliwooly
@amber_ketch
This was a feature back few years ago, it was removed, probably copyright issues, you can use a third party app, I use AZ screen recording
amber_ketch
Too bad, no more YouTube videos on games from individuals.  That's **bleep**😔
They need to solve the copyright problem.
Uliwooly
@amber_ketch
amber_ketch
Thank you for your help and advice.  Just emailed them.  Will see if there is a new update coming including this feature for the Xperia mobile series.
