Folder bug
GTYe0h
Folder bug
Inside app drawer we could create folder which holds 16 apps on a small square and the 17th will be on another new square to the right. Problem is when you apply rearrange app from previous square to the front square the home app crashes every time
GTYe0h
Fixed in 53.0.a.6.88
Xenitism
I tested out myself and it really crashed. Hope Sony notice this bug Slightly_frowning_Face
GTYe0h
