Hi everybody i Wanna change the options for the apps thats works at the start by the Phone can ever
ManfredBucher
Jonas
Master
Hi @ManfredBucher, welcome to our forum!
I'm not quite sure that I fully understand what you want to change. Do you want to edit which applications are started automatically after you power on/restart your device?
If that is what you want to do, there is no setting for this in the device.
I hope that helps and if I misunderstood your question, please do elaborate!
