Notification tones xperia 10 plus
Bijoukat
How do I  personalize notification tones for different apps?
profile.country.NL.title
Strampke
Find settings in the app and tap on notification time.
You can change the led colour to your personal liking too.
pressefr
Settings > Apps & Notifications > Configure Notifications
from what I can see there's no LED Color per app for notification like old-skool Sony.
Sound notifications, now when you add a sound it saves... Back then it would just add a temp. As you see I didn't realize it and saved it multiple times. So you can now switch between a few sounds without re-searching for it in your folders.
