Question: Xperia 10 IV eSIM and DualSIM
hehduda
Hi all,
since the Xperia 10 IV is eSim capable, I want to know if it's possible to load an eSIM and to use a second SIM-card.
Any answer would be appreciated.
Best regards!
EMS_MO72
Community Team
Hi @hehduda
If your Xperia 10 IV is dual SIM version, you can use an eSIM card and a normal SIM card, check this link: https://helpguide.sony.net/mobile/xperia-10m4/v1/en/contents/TP1000669479.html
EMS_MO72
Community Team
Hi @hehduda
hehduda
Hi @EMS_MO72
Excuse me for answering late. I was unable to sign in due to "technical problems" on sony .de.
Thank you for your answre and link!
Since my device is a XQ-CC54 I should be able to use an eSIM.
