Xperia 10 cuts off
Cadest
Xperia 10 cuts off
My Xperia 10 cuts off by the slightest knock. Even if I put it in my pocket upside down it will do it.
I need to hold the power button for 20 seconds to power it back up again. Very frustrating!
6 REPLIES 6
profile.country.PH.title
MarlonUk1
hello @Cadest
just to make sure that it isn't a software problem., can you boot your device to safe mode by long tapping power off option.,
if the problem still persist , it might be a loose connection inside, and it might need to be sent for service
Cadest
Hi.
Yes, can still boot into safe mode.
Even after update problem persists. I am with you with regards to thinking a loose connection inside. Also, my phone doesn't seem to like reconnecting to WiFi once connection is lost (like walking the dog) and then returning. I always need to restart phone when returning. Seems I have multiple issues going on 😭
Laerchen
Hey, I have a similar problem: Since the update to Android 12 59.2.A.0.463 my Xperia 10 II crashes as soon as it loses the connection to wifi. If I leave the wifi completely off, it no longer crashes. Bluetooth does not work anymore either. I hope for an update soon that fixes these problems.
EMS_MO72
Community Team
Hi @Cadest
did you try any troubleshooting steps for this issue?
Cadest
Yes, but to no avail. Even done a fresh software installation just incase. Always had the Xperia's but am really disappointed with the way they are going. Might have to jump ship and try another well known brand 🤷
Piscie
Community Team
Hey @Cadest, have you installed the software via Xperia companion? did it perform a factory data reset as well?
