Xperia 10 II call duration
profile.country.CZ.title
mantaraycz
Hello,
I just got the Xperia 10 II and the only problem I have so far is that every call is stopped after arount 15 and half minutes. Anyone experienced something like that? Is there a settings for it? Provider limits calls at 70 minutes 😕
Uliwooly
@mantaraycz
That's a bit odd, does it happen ALL the time?
could you boot in safe mode to test if a third party app it's causing this?
Safe mode: press the power button > once the screen its on > press and hold the power button > you should see a pop up option to boot in safe mode
