Xperia 10 III Android 12 update (62.1.A.0.533)
SpitfireMk
I just received the update (Spain).
For now, everything seems to work fine, although I absolutely hate the lack of transparency on the notification, app switching and lock pattern screens. The background is just a shade of solid gray. Sadly, it seems to be an intentional design decision from Google's Material You and not a fixable bug as far as I can tell.
mwilkins100
Also updated today (UK) and agree with everything you've highlighted, especially the notifications.
My biggest annoyance is the app group colour which has now changed to white and I am unable to find anyway of changing it:
It can be done by switching to the Dark Theme but that then has an impact on certain apps and other display settings which I don't want.
Tried everything else so any suggestions greatly received!
profile.country.US.title
mksuuk
Try another launcher, for example Nova Launcher?
Piscie
Community Team
You can also try to go to Settings -Apps - Xperia Home - Storage - Manage Space - select OK followed by a hard reset by holding the power and Volume+ at the same time, then check the performance again.
