52mm lens works only with cinemaPro
Yekollu
The 52mm lens works only with Cinema Pro and not with normal camera (or messaging apps like whatsapp). Is this normal? or a hardware bug?
Jrnr
It will work only when light is enough, that means it needs to be a bright environment.
