android
profile.country.NL.title
Quang78
android
i would like to create a group app to arrange differrent apps in one group.
How can i do this?
thank you
profile.country.PH.title
MarlonUk1
hello @Quang78
in order to arrange apps into groups go to the apps drawer. on the upper right side tap on the the 3 dots and select re arrange.. just drag an app on top of another app to create a folder.
MarlonUk1
hello @Quang78
Quang78
wow...alot of thanks !
