Selfie-stick recommendation wanted!
profile.country.DK.title
Gettysburgexpress
Hi.
I bought an Xperia 5ll i may 2021. I had an old - and very cheap - selfie-stick that paired and worked perfectly ... until I broke the stick 😞
So I bought a Baseus Traveler Bluetooth Tripod Selfie stick which have tripod and remote control - both very useful. But it will not work with my Xperia 5ll 😞
Is there any Xperia 5ll users that owns a selfie-stick that works with that model and that is recommendable - then I would be really greatful for that 🙂
Kind regards
Frank
EMS_MO72
Community Team
It seems that Sony doesn't make their own selfie sticks, but I'm sure other brands make them. Maybe you can check with the support of the selfie stick about the compatible phones with it, I think they might have a list.
