Xperia 5 II 5G band question
Kenrw8
Hello,
I'm considering getting the Xperia 5 II but unsure about the 5G compability.
In the UK there has been an auction for 3700 (3600-3800) Ghz band which designated as n77
My question does the 5 II  contrary to the specifications ( 5G BAND Bands n1, n3, n8, n28, n78 ) actual support the 3700 GHz band n77 frequency? That'll used in the UK.
EMS_MO72
Community Team
Hi there, according to the device's specs, these are the bands that the 5G network on the Xperia 5 ll support: n1, n3, n8, n28, n78. But it's also mentioned that availability may vary depending on country, carrier, software version and user environment. So i guess that means that it depends on the operator as well.
EMS_MO72
Community Team
