Xperia 5 - rebooting itself
Davekent1981
Hi everyone - I hope somebody can help, i!m going crazy! My new Xperia 5 arrived a couple of days ago, and was great for half a day until it started rebooting itself!
I've tried a factory reset, and a software repair but I get the same, fine for 3-4 hours and then it kicks into the cycle of rebooting itself every 3-4 minutes. Any suggestions?
Davekent1981
Thanks for the suggestion - it looks like it was an issue with the SIM card, but a faulty SIM. I've hard the same SIM for a few years so maybe wear and tear. Received a new SIM today and all is working perfectly. I can now enjoy my new Xperia phone 😃
5 REPLIES 5
IamNic
Hello @Davekent1981,
with this boot-loop issue I would suggest to get in contact with Sony support via the options listed in this site: https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=mobile
- Nic
profile.country.PL.title
najodleglejszy
@Davekent1981,
one of the things you could try is removing the SIM card and inserting it again, in order to make sure it's inserted correctly and it's sitting tight in the slot. Xperia phones reboot when they detect the SIM card being ejected or inserted, so if the card isn't in contact with the pins all the time, it could cause a reboot.
you could also remove the SIM card completely and check if the phone is still rebooting itself then.
IamNic
Hello @najodleglejszy,
that is a very good suggestion - you are right, if I take out the SIM card while the phone is on, it will reboot.
If it now is not positioned correctly, it will cause the phone to reboot every single time the smartphone runs the SIM detection.
I hope @Davekent1981 gets back to you and reports whether or not that resolved the issue.
- Nic
Davekent1981
najodleglejszy
good to hear that you solved it! enjoy your new phone :slight_smile:
