What happens with USB 2 on Vaio??
mystudio
My Vaio PCG K115s keeps telling me that I am connecting a fast USB hardware to a slow USB port. That's strange, 'cause, I thought all USB ports are USB 2.0 on this Vaio, I thought. It happens when I am connecting more then one USB thing on the USB slots. So, when the logiteck mouse is connected, and I plug in the USB 2 cardreader, I get this pop up screen. When the mouse isnt connected, it doesnt appear.
Is the mouse decreeasing the spead on the USB ports? And, are the three USB slots just on one USB port? What is the workaround, in that case?
Anyone who has an idea, be welcome!
Thanks in advance.
Marco
10 REPLIES 10
kee-lo_
Have you tried the other ports Marco?
I'm sure the K series has USB2.
vaiodon
I think you've just confirmed something I've suspected for a while and have been trying to find the answer to, i.e., when a USB1.1 device is plugged into a USB2 port that USB interface runs at the speed of the slowest device.
I've got an RZ series desktop with 8 USB ports served by 4 controllers. I have tried to keep USB2 and USB1.1 devices segregated across the controllers avoiding mixing USB2 and 1.1 devices on the two ports shared by one controller.
Don't know how many USB ports your Vaio has but you might be shafted if there's only 2!
A fix might be to put a 4 port USB2 controller/hub outboard of the Vaio - that, I think, will ensure that the Vaio port runs a full USB2 speed while each port on the hub will run according to what's attached.
smoking
Hello Mystudio,
I only recently purchased my Vaio having previously owned an older Dell which only had USB 1 . I had similar problems when I connected a USB 2 device to the Dell , Vaiodon is correct in saying that the device will run at the slower speed.
Might I suggest you have a look at the following sites that I came across at the time , which I found very helpful and informitive.
www.usbman.com
www.pcbuyerbeware.co.uk/USB.htm
vaiodon
Following up on smoking's links my suspicions and my last paragraph fully confirmed.
(At the risk of supplying too much information...) the USB 2.0 hub design includes something called a "transaction translator" that allows data from USB1.0(~1Mbps), USB1.1 (12Mbps), USB2.0 (480Mbps) devices all to be buffered onto a host side USB2.0 bus running at 480Mbps.
A Belkin Tetra Hub T4 (F5U231) seems to be the mutts nuts as it has one TT per downstream port.
kee-lo_
Belkin's gear is very good.
mystudio
Well.....I have tried all ports and all have the same problem. That say, when only one USB 2 device is connected, there is no problem. The problem appears when the mouse (logitech/led/wheelmouse) is connected to anu USB port and a USB 2 device is also being connected somewhere on one of the three ports.
Does the Vaio have only one controller for three ports? In that case, when you connect an USB 2 hub, the problem will remain, doesn't it?
kee-lo_
If thats the case then yes.
You would have to consider getting a USB2.0 cardbus card.
mystudio
Well, I don't know if that's the case, but if it IS, I would say it's a bad design idea from the boyz of Sony.........why would they do that?
:devil:
kee-lo_
Because they suck.
No idea, doesn't make sense to me at all.
