Edge App on RX10 M3
Edge App on RX10 M3
Does anybody know how I upload the Edge App onto the RX10? Now that PlayMobile has been dropped I need the App on the camera so that I can have full control of all of the settings rather than just firing off the release.
Tags (1)
Mick_D
Moderator
Hi @Colin_Shead, welcome to the community.
I'm not sure I understand correctly – if you're looking to use the Imaging Edge app, you need to download it to your phone in order to use it in conjunction with your RX10.
Let me know if you need more help with that.
Mick
