Sony FDR 1000 external mic problems
lauris46
Hello,
I have issues with camera external microphone. I have bought stereo microphone, but when I plug, record video with it, the left channel most of the times will have ticking sound. I have attached video example. I know that it is not a microphone problem, I tried multiple microphones.
Also, what 3.5 jack suppoose to go inside external plug? there is tripple and 4 layered 3.5 plugs which one is inside fdr 1000 ?
Video example
https://www.youtube.com/watch?v=7SvV-6YCK-U
What is the input:
This: https://cdn.sparkfun.com//assets/parts/6/6/0/4/11143-01.jpg
or this: http://www.ifuturetech.org/ifuture/uploads/2016/04/3.5-mm-audio-jack.jpg
Thanks.
IamNic
Hi there ,
the input is a TRS (Tip Ring Sleeve) input.
The tickling sound can be a result of the cameras WiFi (if switched on) or your smartphone sending/receiving something via mobile data interfering with the coil inside the microphones capsule.
- Nic
