Sony HX200V
Lloydh
Sony HX200V
My Sony HX200V after not being used for a year will not go past the select English Language after chargeing the battery.
Pascale_F
Moderator
Hi Lloydh,
Welcome to the community.
I'll see if I can track down an answer, but maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Lloydh
At this point there are two things to try:
1- Remove the battery for a few minutes and put it back in.
2- Reset the camera manually by pressing the Reset button (#29 in the parts shown here) using a pin.
If the issue remains, I'd recommend getting in touch with the Sony Centre to check the option of repairing it using this number: 01656 867347.
Win_88
