Underwater filming HDR AS15
Pipen03
What happens with the quality of the picture when i submerse my camera ?
The picture quality is awfull.
Take a look   http://youtu.be/uQvjQl83tRU
Nobody-in-particular
Hi Pipen03, according to the manual the image quality is not expected be the as clear when used under water. Check out other Action cam underwater footage that owners have uploaded to youtube and you will see your footage is of a similar quality.
5 REPLIES 5
Pipen03
Ok, I´ll check that out. Thanks for participating to my topic 😉
Pipen03
Just finished checking out some underwater footage as you proposed and it seems you are very right indeed.
I guess I expected too much of the AS15 then !
Thanks a bunch anyway 😉
Glad I could help just sorry it wasn't the answer you were looking for.
johnohuk
Have you got the correct Flat port on ? The curverd ones which you get with it distort the picture something rotten underwater...
I've had some success underwater... but low light is always going to be an issue.
http://johnohuk.blogspot.co.uk/
http://www.youtube.com/user/johnohuk2
