20mm 1.8 autofocus jumping
Amadeus2020
Hi. I have a brand new SONY 20mm f1.8 lens. SEL20F18G, attached to an A7iii.  When in continuous focus, the image on screen jumps in and out considerably as the autofocus is moving around. Is this normal? It 'zooms' in and out quite a lot as the internal mechanism moves forwards and backwards trying to find the focus. I have never seen it before on a SONY lens (I have the 55mm prime). It does not occur when the camera is in Auto, but is quite pronounced when it is in AP mode.
7 REPLIES 7
Peter_S.
Genius
Hi Amadeus,
Try to use a different aperture other than 1.8.
Guess there's too much light getting onto the focus sensor.
Peter
Amadeus2020
Hi. Thank you for replying. Actually, it is far worse at f8, 9, 10 and higher. When it's at 1.8 it's pretty stable.
Joe_Dohn
Specialist
Does this happen on the latest software version as well? I recall seeing some restrictions on this lens with the camera which recommended the latest software version (if I'm not mistaken).
Amadeus2020
Thank you. Software? Do you mean the firmware for the A7iii? I have googled it and found nothing. Sony has no updates that I can see pertaining to the 20mm.
Win_88
Specialist
Hi @Amadeus2020
I found a firmware update on the Sony website for the A7III:
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7m3
Win_88
Amadeus2020
Thank you that's helpful. I've updated. But Sony tell me that's completely normal for this lens because of the internal mechanism (!).
Win_88
Specialist
Hi @Amadeus2020
Having had experience with Sony support myself, If you were given that answer, it must've been the result of an investigation and the info is accurate. It must be within specifications.
Win_88
