unable to read memory card. rinsert memory card.
wht can I do?
Hello @nader44,
did you insert the memory cards the right way round?
Most Sony cameras accept MemoryStick cards and SD-cards so the memory card slot has contacts on both sides.
Next to the slot you should see a little pictogram on how to insert the card correctly.
- Nic
