a6500 screen protector
ijscotter
Has anyone found a screen protector for the a6500 which maintains the touch sensitivity of the screen?
Sony suggest the PCK-LS1EM but I can't see anything which says that it is touch sensitive and it is also recommended for the a6000 etc.  Also, in the photo on Amazon of the packaging there appears to be no mention of the a6500, although other cameras in the series are listed.
Thanks.
cass_n
Community Team
Hi @ijscotter and welcome to the community :slight_smile:
You can check the accessory chart here and filter for the a6500: https://www.sony.net/Products/diacc/systemchart/en-gb/index.html#ilc
According to this, either PCK-LS1EM or PCK-LM should work.
Hope that helps.
Cheers,
Cass
Barton14
I bought the Sony PCK-LS1EM screen protector for my A6500. The screen protector was sourced directly from Japan via ebay after finding no availability in the UK.
The package does state the protector is for the 6500 along with 6300, 6000, 5100, 5000, 3500 and 3000. Also stated is that the sheet is Anti Reflective and Anti Scratch.
The protector is adhesive, quite thin and flexible, applied easily enough and after application, the touch screen functions do appear to work normally.
I hope this information is useful.
