A6700 Battery save setting not working
profile.country.SE.title
ilwardh
I have tried to enable the battery save function according to the manual.
Either it is not working or I am doing something wrong.
If I forget to turn off the camera, the battery will be emptied after a while (don't know how much time)
The camera alos feels warm.
Any suggestions what to do?
Thanks in advance
/ilwardh
danardeng
Are you sure you have Bluetooth Rmt Ctrl turned off according to manual?
https://helpguide.sony.net/ilc/2320/v1/en/contents/0601B_power_save_start_time.html
