After using the flash a few times, it inevitably stops working. I understand that the flash can only fire a certain number of times before needing a rest.
Yes, I've heard reports of this behaviour, don't think it's unique to your camera at all. It's an issue for people using the built-in flash as a controller for wireless flash operation, surprised because the flash discharge is restricted to mimimum output, yet it still cuts out.
I agree it sounds like buggy behaviour, but I'm more swayed by arguments that suggest a deliberate restriction on flash discharge rates to prevent posisble overheating. The reasoning being that the flash has no in-built overheating sensor which might disable the unit in that eventuality. Hence you have a 'numbers-of-flashes' limitation, regardless of output, on the basis that most users will not be using it at 1/8 output.
I'm guessing at this, as I say, so I've asked for clarification from some Sony techs. I'll post up the reponse as/when I get one.
Mick
Thanks for taking this up. Can I just add that when the flash stalls, it is not hot at all, not even warm. It's not just wireless triggering affected but any flash. As an overheat protection, it's not too effective as after just a few seconds in sleep mode, it is cured.
Finally, my a55 and a700 could flash away till the cows come home (or the battery ran out). It seems to be an a65/77 peculiarity....
Did you get any feedback from the engineers about this one?
Not as yet, no. It's early days really, given the holiday season just ending and the concomitant backlog of enquiries that flood their way following the busiest trading month of the year...
The idea that this is a deliberate restriction on flash discharge due to the lack of in-built overheating sensor was vaguely agreed upon by a colleague who seemed to recall this being brought up while addressing another issue.
Basically Sony do tend to err on the side of caution, and when there's a possibility of damaging a heat-sensor-less flash on a camera capable of 12 frames per second, it wouldn't surprise me to learn that a flash count limit was hard-coded into the firmware.
As I say, if I hear anything either way I'll let you know here.
Mick
I normally use radio triggers, but due to a battery malfunction (I forgot to pack spares for the receivers) I had to use the popup flash to trigger 2 F42s the other day, and I came across this problem.
This is a really, really serious issue for me - has anyone found a workaround, or are there any plans for a fix?
