a77 SLT viewfinder shows only green stripes. What might be causing this issue?
BBarrett6
My a77 lately sometimes shows only green stripes in the viewfinder.  If I change the lens, it may continue showing the green stripes or it may work properly.  I've tried changing batteries and SD cards and that doesn't help.  On one occasion with a fully charged battery, the camera would not turn on.  This was after I had connected the camera to my pc, Windows 10 OS, to download photos using a USB cable.  The USB cable is relatively new and shows no wear or damage.  The next day, I turned the camera on and it works properly.  My camera has not been dropped or used in the rain.  Any ideas on how to get it back to working correctly?
Tags (1)
Sean_Mc
Moderator
Hi BBarrett6,
I would recommend getting in touch with Support for further advice on this here.
Cheers,
Sean Mc
