Dear Cummunity. I have recently changed over from the higher end of bodies and lenses from Canon to the recent Sony alpha 7RII and want to know what will be the best dedicated flash unit to buy, which is compatible with this a7RII camera?
Grateful for any advice on this please.
Kind regards
Solved! Go to Solution.
Hi Hoofy247 and welcome.
It will depend on what you are going to use the flash for. Do you need the high power of the F60M or will the F43M meet your needs? If you don't need the power and sophistification of these top of the range models, have a look at the F32M or the F20M.
Have a look at the available accessories here: -
Have a look at the Nissin Di700. Reasonably powerful but the big plus is it syncs with a commander unit which can be mounted on the camera's hot shoe allowing the flash to be positioned wherever you want it.
